@Gero: Read the first line of the @MariMakes answer : "There will indeed be an update on the wall ordering, one contributed by the community. You can find it here."
The answer is here 😁
For the more adventurous, version 5.5 Alpha also solves this issue.
Edited by Cuq
10
7
5
4
Popular Days
Sep 11
8
Aug 24
7
Sep 12
4
Jul 6
3
MariMakes 10 posts
GregValiant 7 posts
Gero 5 posts
fc2kool 4 posts
Popular Days
Sep 11 2023
Aug 24 2023
Sep 12 2023
Jul 6 2023
Popular Posts
Gero
I still think Ultimaker's decision to reverse the default order of walls is counterproductive. Here I have comparison images of an Ultimaker S5 and a Bambulab X1. Same objects, same filam
ArunC
The full stable release of UltiMaker Cura 5.4 is here and it makes it easier than ever to remove brims and supports from your finished prints. UltiMaker S series users can also look forward to print p
Travis90x
Hi, on Cura 5.4 how can I restore layer view like Cura 5.3? How restore "Select face to align to the build plate"? Why they change stuffs without let the user choose during installation? Why the
Posted Images
Gero 54
Thanks for the answer!
However, I'm afraid that simply changing the basic setting won't help too much.
Part of the problem is that all the inner walls are printed first, one after the other, and finally all the outer ones. On a simple sheet with multiple holes, this results in each hole being approached multiple times. Since here, too, a re-retraction is first carried out for each outer wall, the typical under-extrusion error pattern occurs, since here the complete material flow is not achieved directly after the retraction.
To prevent this, the walls of a closed geomembrane must be printed one behind the other, as in the earlier cura 4 versions, so that a uniform material flow is finally present at the nozzle for the outer wall.
