Part won't print
Jerrymc3
Posted · Part won't print
I made this gear for dual servos in Blender 3.5.  When I open it in Cura it doesn't show any errors but when I slice it , it shows 0g.  Maybe it needs to be made solid but I don't know how.
DualServoGear_1.thumb.jpg.80cdc3bd390bee48774663070b3b30bf.jpgDualServoGear_2.thumb.jpg.5e137fc48d36b49edf690cdcbb36cf86.jpg
    Try loading the model into 3D Builder (which comes free with Windows). It will complain that the model is "invalidly defined" and offer to repair it. Then export the model as a new version.
    Posted (edited) · Part won't print
    Sorry there @Jerrymc3 but that model is put together in such a way that it simply won't slice.
    This is at 5X size in Cura.
    Here it is at 5X size in PrusaSlicer.
    Here my copy of the model is on the left.
    Edited by GregValiant
    So will your copy slice and can you send it to me or is there a way to fix mine?
    Jerry
    I've made it a policy not to do peoples homework for them.  You can probably repair the model in Blender.  I think there is something going on with the very bottom as it never wants to slice.
    It's sort of a funny deal.  My normal tools for determining model errors all say that your model doesn't have any errors and yet no slicers can deal with it.  Something is going on and Blender is the place to fix it.
    Here is your model from the bottom.  Is there a command in Blender to "Make Solid" or something like that?  You can see that the bottom appears to be missing.
    On 7/23/2023 at 4:55 PM, Jerrymc3 said:
    Sorry its taken me so long to get back to this but I've been very busy.  Here is the stl file created in blender.
    The stl file seems to contain two overlapping copies of the same object. There was perhaps more than one object selected while doing the export in Blender or something went wrong during a boolean operation beforehand.
    Hope that helps!
