It would be helpful if you could post a vide showing the relative tension of the top and bottom parts. As George mentions, if the tension is uneven, you can just redistribute the tension by loosening and retightening one of the pulleys. Alternatively, if the belt just seems to be too long, then maybe there is a problem with the tensioner. You could just add a UM1-style tensioner to the part of the belt that the sliding block doesn't attach to e.g., the wave tensioner:
http://www.thingiverse.com/thing:19892
Or alternatively attach a spring, like the ones used in clothes pins.
gr5 2,071
The blocks I believe have some kind of tensioner inside but I know of no one who as opened one to see.
Consider loosening the pulley for the "bad" belt and distributing the tension to both top and bottom and then retighten the pulley.
