5 hours ago, friedl_basson said:I was wondering whether anybody is experiencing the problem where the printer would lose connection to Digital factory permanently. In network settings I have an IP address, but the "connect to digital factory" button is greyed out and a message is indicating that I require a network connection.
Going back to network settings I can clearly see the IP address. Further to this, the WiFi icon on the printer clearly indicates it is connected. I have also tried connecting to LAN cable directly, but the same problem persists.
No solution, but I have the same problem with my S5. The S3 and the S5 are in the same room, same access point. S3 is stable, but the S5 gets disconnected after some time. It is not a local network issue, I can SSH and ping the printer. But it is disconnected in DF. A power cycle helps to bring it back online for some time. Very annoying...
1
Dustin 73
Hi @friedl_basson
I would recommend reaching out to UltiMaker Support directly for this issue.
There is likely information they can gleam from the machine log files.
Usually the issue is related to some sort of network blocking issue.
You can learn about network requirements here: https://support.makerbot.com/s/article/1667337958118
If you still have issues, get a copy of your machine log file after you experience the issue and send it to UltiMaker
Guide for exporting log files: https://support.makerbot.com/s/article/1667337561393
Contact UltiMaker here: https://support.makerbot.com/s/contactsupport
