Camera is still available in 8.X but you need to turn off the firewall. There is a firewall feature on the printer but it blocks camera feed. Could that be it?
Also the way you see the camera *might* be different. Instead of using that 8080 URL, go to the printer from within cura and there is this blue circle with a camera icon in it. Click that to see the camera "live" (one image very 10 seconds or so?).
gr5 2,333
Did you upgrade firmware recently? I know some features were removed with version 8.X, but I don't see anything in the release notes about the camera feed. Can you get to the computer's web page at all?
The camera used to be on port 8080 (instead of the default html page of 80). Maybe your network has that port blocked?
502 is not that common of an error. I'm wondering if you are going through a proxy server or if the error comes directly from the printer. I would hit the F12 key in your browser and then go to the network tab and then do and F5 (refresh page) and click the line that gets the 502 and look at the headers. Often the headers have MUCH more information.
I would also turn off the printer to see if you get a different error. If you get 502 with the printer on and 504 (or other #) with the printer off then the problem is probably with the printer and not your network.
