Is it possible to print two different colors in the same piece with the Ultimaker S5?
AnaLara
Posted · Is it possible to print two different colors in the same piece with the Ultimaker S5?
Hi all,
I would like to ask you if it is possible to print in two different colors for the same piece using the printer Ultimaker S5 with extruders AA y BB.
Thank you so much.
Best regards.
    On 9/25/2023 at 12:21 PM, AnaLara said:
    Hi all,
    Thank you so much.
    Best regards.
    Yes, this is possible just make sure you split (have TWO different) .stl files.
    stl file 1 = Colour 1
    stl file 2 = Colour 2
    Hi AnaLara,
    I have used this to print architectural facade models
    • separate your digital file so that each material you want your print to be is a different group of objects but the item looks like you want it to be
    • make sure these two groups have the same origin and rotation
    • export two different stl files from your design software for each of the groups
    • open the two stl files in CURA. The files will be separate
    • select each of the objects and change their material by clicking the roll button on the left of the screen.
    • select both objects and right click
    • select merge models
    • print
        • 20 replies
