There are tons of possibilities. humid filament is unlikely at this point. I don't recommend buying more PVA. If you are going to buy something consider buying "breakaway" filament (if your model can work with that kind of support - some models have too many inner caves where you wouldn't be able to remove the breakaway).
Well it seemed to print much better for the second part. So I'm thinking the filament wasn't all the way installed.
Before installing the filament I always cut it to a point using wire cutters. I do two angled cuts to make a point.
I always choose the MOVE command in the printer menu and then left the lever on the feeder, slide the filament all the way in, wait for it to get above 160C and then start to use the down arrow in the move feature. While doing this I feel the filament on the back so I can tell if it is truly moving or stuck.
Once the nozzle is at temp you can make a zig/zag in the filament near the nozzle and then see how quickly you can get it to reach the bed. If it can reach the bed in 5-8 seconds you are fine. Even 10 seconds isn't too bad. If it takes more than 12 seconds then something is probably wrong.
Let's assume it's fine at this point. Well now we also know the filament is fully loaded so try the print again.
There is a bug in some versions (all versions?) of the firmware when you abort a print or certain special cases (calibration test?) where it retracts the filament a bit too much and if you abort twice in a row the filament doesn't get into the nozzle until you've been printing a few minutes. I'm thinking either you didn't load fully or it's that bug.
The above tests should allow you to distinguish between several different types of problems (be sure filament extrudes quick enough, be sure it's installed all the way).
gr5 2,333
Well you changed the BB core so I think it's probably the PVA itself. I think it got wet. Maybe even before it arrived to you. It would help if you could show the first layer better.
Also, do you have the Material Station?
keeping PVA dry
So PVA is very different from PLA. It's harder to print. It doesn't stick to itself so amazingly well like PLA. keep it with 1/4 liter (one cup) of dessicant at all times. I NEVER leave it overnight on the printer, etc.
One sign the PVA is too wet is it snaps and pops and hisses and you can actually often see steam coming out at the nozzle tip while it prints. The PVA ends up being snowy instead of clear because it has tiny steam bubbles embedded (hence the snowy look). If it's only a "little" wet you won't notice the noise or steam but it will still be snowier than usual.
When PVA is wet like this it expands too much and so it overextrudes. Enough to get lots of stringing and other issues (sometimes it doesn't stick well to the print bed).
It's easy to fix with heat. In cura look up how many meters of PVA are needed for your print. Unspool that much, place on the heated bed, put the spool on top (no need to cut the PVA). Put a towel over all that and another blanket on top of that and heat at 65C for 4 to 8 hours. That should be enough to get you going on your print. To dry the whole spool, dry it for 24-48 hours (not necessarily all at once).
Going forwards keep it in a 2 gallon zip lock with LOTS of desiccant. And recharge the desiccant every month. I buy it in liter jugs and store it in a container with a lid that stops the desiccant from coming out but allows air exchange. I use color changing desiccant that can be reheated (dried) in the microwave.
martinstyner 3
Thanks, I tried to dry it out (8 hour drying at 65C with towel, unspooled plenty, more than enough for the calibration print, which I am using as it only prints a few layers) and the result did not change. The attached photo shows a closeup , the vertical lines were not printed at all and the horizontal lines are spotty, rather than nice and clean. This print had plenty of magig-glue on it (i do not think it's adhesion).
The issue seems to be though less one of over-extruding, but under-extruding.
I will do another one with the spool having been dried for 24h.
Btw, I do not have a material station, but i put away my PVA after each print job and keep it in a sealed plastic bag with desiccant (though I could probably use more of it).
Could it be the feeder that needs replacement? Before I try that, I will order a new spool of PVA and try again with that one.
Best
Martin
