Heads up for next time: you can upload files into your post by dragging and dropping them into the text box. Doesn't allow all file types, but for whatever it doesn't support you can just put it in a zip file and upload that.
So two things:
1) If it's actually creating a cura.cfg file in the same folder as the log, could you please upload that (that one you will need to put in a zip, it says at the bottom what file types you can attach)
2) Try running Cura as an administrator (right click > Run as administrator) and see if that makes a difference. It shouldn't, in theory, because a program doesn't need admin rights to write and read from %APPDATA%, but it's worth a try, because the log file looks like it can't create a preferences file.
Edited by Slashee_the_Cow- 1
Slashee_the_Cow 295
Is there a cura.log file being generated in %APPDATA%\cura\5.5 ? If you could upload that it would really help.
ultimategeek 1
Thanks, I was looking for another one, here it is
2023-10-28 18:49:30,846 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [89]: Adding QT6 plugin path: C:\Program Files\UltiMaker Cura 5.5.0\PyQt6\plugins
2023-10-28 18:49:30,846 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [99]: Adding QT5 plugin path: C:\Program Files\UltiMaker Cura 5.5.0\PyQt6\plugins
2023-10-28 18:49:30,846 - DEBUG - [MainThread] UM.Application.initialize [163]: Initializing UltiMaker Cura
2023-10-28 18:49:30,847 - DEBUG - [MainThread] UM.Application.initialize [164]: App Version 5.5.0
2023-10-28 18:49:30,847 - DEBUG - [MainThread] UM.Application.initialize [165]: Api Version 8.5.0
2023-10-28 18:49:30,847 - DEBUG - [MainThread] UM.Application.initialize [166]: Build type None
2023-10-28 18:49:30,847 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\lib\uranium must be a folder.
2023-10-28 18:49:30,848 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\lib64\uranium must be a folder.
2023-10-28 18:49:30,848 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\lib32\uranium must be a folder.
2023-10-28 18:49:30,849 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\UltiMaker Cura 5.5.0\plugins must be a folder.
2023-10-28 18:49:30,849 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
2023-10-28 18:49:30,849 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
2023-10-28 18:49:30,849 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [481]: Initializing storage paths
2023-10-28 18:49:30,849 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [491]: Config storage path is C:\Users\iain\AppData\Roaming\cura\5.5
2023-10-28 18:49:30,849 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [499]: Data storage path is C:\Users\iain\AppData\Roaming\cura\5.5
2023-10-28 18:49:30,849 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [511]: Cache storage path is C:\Users\iain\AppData\Local\cura\5.5\cache
2023-10-28 18:49:30,850 - DEBUG - [MainThread] UM.Resources._copyLatestDirsIfPresent [536]: Found config: ['C:\\Users\\iain\\AppData\\Roaming\\cura', 'C:\\Users\\iain\\AppData\\Local\\cura'] and data: ['C:\\Users\\iain\\AppData\\Roaming\\cura', 'C:\\Users\\iain\\AppData\\Local\\cura']
2023-10-28 18:49:30,850 - DEBUG - [MainThread] UM.Resources._copyLatestDirsIfPresent [540]: Latest config path: None and latest data path: None
2023-10-28 18:49:30,850 - INFO - [MainThread] UM.Qt.QtApplication.initialize [164]: Preferences file not found, ignore and use default language 'en_US'
2023-10-28 18:49:30,850 - INFO - [MainThread] UM.PackageManager.__init__ [56]: Found bundled packages JSON file: C:\Program Files\UltiMaker Cura 5.5.0\share\uranium\resources\bundled_packages\uranium.json
2023-10-28 18:49:30,850 - INFO - [MainThread] UM.PackageManager.__init__ [56]: Found bundled packages JSON file: C:\Program Files\UltiMaker Cura 5.5.0\share\cura\resources\bundled_packages\bundled_CuraEngineGradualFlow.json
2023-10-28 18:49:30,850 - INFO - [MainThread] UM.PackageManager.__init__ [56]: Found bundled packages JSON file: C:\Program Files\UltiMaker Cura 5.5.0\share\cura\resources\bundled_packages\cura.json
2023-10-28 18:49:30,850 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [124]: Trying OpenGL context 4.1...
2023-10-28 18:49:30,851 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [132]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
2023-10-28 18:49:30,851 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [192]: Detected most suitable OpenGL context version: 4.1 Core profile
2023-10-28 18:49:30,851 - INFO - [MainThread] UM.Qt.QtApplication.initialize [199]: Initializing job queue ...
2023-10-28 18:49:30,851 - INFO - [MainThread] UM.Qt.QtApplication.initialize [203]: Initializing version upgrade manager ...
2023-10-28 18:49:30,851 - INFO - [MainThread] UM.PackageManager._loadManagementData [174]: Loaded bundled packages data from C:\Program Files\UltiMaker Cura 5.5.0\share\uranium\resources\bundled_packages\uranium.json
2023-10-28 18:49:30,851 - INFO - [MainThread] UM.PackageManager._loadManagementData [174]: Loaded bundled packages data from C:\Program Files\UltiMaker Cura 5.5.0\share\cura\resources\bundled_packages\bundled_CuraEngineGradualFlow.json
2023-10-28 18:49:30,851 - INFO - [MainThread] UM.PackageManager._loadManagementData [174]: Loaded bundled packages data from C:\Program Files\UltiMaker Cura 5.5.0\share\cura\resources\bundled_packages\cura.json
2023-10-28 18:49:30,852 - INFO - [MainThread] UM.PackageManager._loadManagementData [203]: User package management file C:\Users\iain\AppData\Roaming\cura\5.5\packages.json doesn't exist, do nothing
2023-10-28 18:49:30,852 - INFO - [MainThread] UM.PackageManager._removeAllScheduledPackages [280]: Attempting to remove the following scheduled packages: -
2023-10-28 18:49:30,852 - WARNING - [MainThread] UM.PluginRegistry.addPluginLocation [203]: Plugin location C:\Program Files\lib\cura must be a folder.
2023-10-28 18:49:30,854 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin FileLogger 1.0.1
2023-10-28 18:49:30,878 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin LocalContainerProvider 1.0.1
2023-10-28 18:49:30,904 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin LocalFileOutputDevice 1.0.1
2023-10-28 18:49:30,927 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin CameraTool 1.0.1
2023-10-28 18:49:30,951 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin MirrorTool 1.0.1
2023-10-28 18:49:30,981 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin RotateTool 1.0.1
2023-10-28 18:49:31,007 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin ScaleTool 1.0.1
2023-10-28 18:49:31,029 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin SelectionTool 1.0.1
2023-10-28 18:49:31,063 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin TranslateTool 1.0.1
2023-10-28 18:49:31,112 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [69]: Checking for new version
2023-10-28 18:49:31,121 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin UpdateChecker 1.0.1
2023-10-28 18:49:31,249 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin SimpleView 1.0.1
2023-10-28 18:49:31,354 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin 3MFReader 1.0.1
2023-10-28 18:49:31,385 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin 3MFWriter 1.0.1
2023-10-28 18:49:32,027 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin AMFReader 1.0.0
2023-10-28 18:49:32,070 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin CuraDrive 1.2.0
2023-10-28 18:49:32,237 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.__init__ [108]: Found CuraEngine at: C:\Program Files\UltiMaker Cura 5.5.0\CuraEngine.exe
2023-10-28 18:49:32,240 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin CuraEngineBackend 1.0.1
2023-10-28 18:49:32,254 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [232]: Socket state changed to Listening
2023-10-28 18:49:32,279 - INFO - [MainThread] UM.Backend.Backend.startEngine [96]: Started engine process: C:\Program Files\UltiMaker Cura 5.5.0\CuraEngine.exe
2023-10-28 18:49:32,279 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [140]: [Backend] Calling engine with: ['C:\\Program Files\\UltiMaker Cura 5.5.0\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
2023-10-28 18:49:32,314 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin CuraEngineGradualFlow 0.1.0
2023-10-28 18:49:32,326 - DEBUG - [EngineOutputThread] UM.Backend.Backend._backendLog [140]: [Backend] [2023-10-28 18:49:32.326] [info] Connecting to 127.0.0.1:49674
2023-10-28 18:49:32,338 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin CuraProfileReader 1.0.1
2023-10-28 18:49:32,338 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [236]: Socket state changed to Connected
2023-10-28 18:49:32,338 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [225]: Backend connected on port 49674
2023-10-28 18:49:32,357 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin CuraProfileWriter 1.0.1
2023-10-28 18:49:32,432 - DEBUG - [EngineOutputThread] UM.Backend.Backend._backendLog [140]: [Backend] [2023-10-28 18:49:32.432] [info] Connected to 127.0.0.1:49674
2023-10-28 18:49:32,504 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin DigitalLibrary 1.1.0
2023-10-28 18:49:32,542 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin FirmwareUpdateChecker 1.0.1
2023-10-28 18:49:32,561 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin FirmwareUpdater 1.0.1
2023-10-28 18:49:32,578 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin GCodeGzReader 1.0.1
2023-10-28 18:49:32,598 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin GCodeGzWriter 1.0.1
2023-10-28 18:49:32,617 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin GCodeProfileReader 1.0.1
2023-10-28 18:49:32,654 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin GCodeReader 1.0.1
2023-10-28 18:49:32,675 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin GCodeWriter 1.0.1
2023-10-28 18:49:32,701 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin ImageReader 1.0.1
2023-10-28 18:49:32,721 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin LegacyProfileReader 1.0.1
2023-10-28 18:49:32,742 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin MachineSettingsAction 1.0.1
2023-10-28 18:49:32,864 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [145]: No auth data to retrieve the access_token from
2023-10-28 18:49:32,870 - DEBUG - [MainThread] cura.UltimakerCloud.UltimakerCloudScope.requestHook [30]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v8.5.0/packages/package-updates?installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=FirmwareUpdater:1.0.1&installed_packages=STLWriter:1.0.1&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=SupportEraser:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=VersionUpgrade52to53:1.0.0&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=X3DReader:1.0.1&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=TrimeshReader:1.0.0&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=CuraProfileWriter:1.0.1&installed_packages=GCodeReader:1.0.1&installed_packages=LegacyProfileReader:1.0.1&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=ImageReader:1.0.1&installed_packages=VersionUpgrade413to50:1.0.0&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=CuraProfileReader:1.0.1&installed_packages=UFPReader:1.0.0&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=UpdateChecker:1.0.1&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=OBJWriter:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=SentryLogger:1.0.0&installed_packages=AMFReader:1.0.0&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=RotateTool:1.0.1&installed_packages=ModelChecker:1.0.1&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=MirrorTool:1.0.1&installed_packages=DigitalLibrary:1.1.0&installed_packages=SimulationView:1.0.1&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=GCodeGzReader:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=UFPWriter:1.0.1&installed_packages=OBJReader:1.0.1&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=3MFReader:1.0.1&installed_packages=ScaleTool:1.0.1&installed_packages=XRayView:1.0.1&installed_packages=CuraEngineGradualFlow:0.1.0&installed_packages=GCodeProfileReader:1.0.1&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=PolyFlexPLA:1.0.1&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=GenericPETG:1.4.0&installed_packages=GenericPP:1.4.0&installed_packages=GenericCPE:1.4.0&installed_packages=GenericCFFCPE:1.4.0&installed_packages=UltimakerBAM:1.4.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=OctofiberPLA:1.0.1&installed_packages=UltimakerTPLA:1.4.0&installed_packages=GenericTPU:1.4.0&installed_packages=GenericHIPS:1.4.0&installed_packages=UltimakerTPU:1.4.0&installed_packages=UltimakerABS:1.4.0&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=GenericBAM:1.4.0&installed_packages=GenericNylon:1.4.0&installed_packages=FABtotumNylon:1.4.0&installed_packages=FABtotumABS:1.4.0&installed_packages=VertexDeltaPET:1.4.0&installed_packages=UltimakerCPEP:1.4.0&installed_packages=UltimakerPLA:1.4.0&installed_packages=GenericABS:1.4.0&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=FABtotumTPU:1.4.0&installed_packages=PolyMaxPLA:1.0.1&installed_packages=GenericToughPLA:1.4.0&installed_packages=GenericPVA:1.4.0&installed_packages=Filo3DPLA:1.0.1&installed_packages=UltimakerPP:1.4.0&installed_packages=GenericPC:1.4.0&installed_packages=PolyPlusPLA:1.0.1&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=VertexDeltaABS:1.4.0&installed_packages=FABtotumPLA:1.4.0&installed_packages=UltimakerCPE:1.4.0&installed_packages=GenericCPEPlus:1.4.0&installed_packages=UltimakerNylon:1.4.0&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=GenericGFFCPE:1.4.0&installed_packages=PolyWoodPLA:1.0.1&installed_packages=GenericPLA:1.4.0&installed_packages=GenericGFFPA:1.4.0&installed_packages=UltimakerPVA:1.4.0&installed_packages=UltimakerPC:1.4.0
2023-10-28 18:49:32,872 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin Marketplace 1.0.0
2023-10-28 18:49:32,893 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin ModelChecker 1.0.1
2023-10-28 18:49:32,912 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin MonitorStage 1.0.1
2023-10-28 18:49:32,939 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin PerObjectSettingsTool 1.0.1
2023-10-28 18:49:32,962 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin PostProcessingPlugin 2.2.1
2023-10-28 18:49:32,980 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin PrepareStage 1.0.1
2023-10-28 18:49:32,998 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin PreviewStage 1.0.1
2023-10-28 18:49:33,031 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin RemovableDriveOutputDevice 1.0.1
2023-10-28 18:49:33,072 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin SimulationView 1.0.1
2023-10-28 18:49:33,094 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin SliceInfoPlugin 1.0.1
2023-10-28 18:49:33,116 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin SolidView 1.0.1
2023-10-28 18:49:33,136 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin SupportEraser 1.0.1
2023-10-28 18:49:33,155 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin TrimeshReader 1.0.0
2023-10-28 18:49:33,176 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin UFPReader 1.0.0
2023-10-28 18:49:33,197 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin UFPWriter 1.0.1
2023-10-28 18:49:33,224 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin UltimakerMachineActions 1.0.1
2023-10-28 18:49:33,531 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin UM3NetworkPrinting 2.0.0
2023-10-28 18:49:33,596 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin USBPrinting 1.0.2
2023-10-28 18:49:33,635 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade21to22 1.0.1
2023-10-28 18:49:33,658 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade22to24 1.0.1
2023-10-28 18:49:33,681 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade25to26 1.0.1
2023-10-28 18:49:33,700 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade26to27 1.0.1
2023-10-28 18:49:33,722 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade27to30 1.0.1
2023-10-28 18:49:33,742 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade30to31 1.0.1
2023-10-28 18:49:33,762 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade32to33 1.0.1
2023-10-28 18:49:33,781 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade33to34 1.0.1
2023-10-28 18:49:33,799 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade34to35 1.0.1
2023-10-28 18:49:33,819 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade35to40 1.0.0
2023-10-28 18:49:33,839 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade40to41 1.0.1
2023-10-28 18:49:33,858 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade411to412 1.0.0
2023-10-28 18:49:33,877 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade413to50 1.0.0
2023-10-28 18:49:33,898 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade41to42 1.0.0
2023-10-28 18:49:33,918 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade42to43 1.0.0
2023-10-28 18:49:33,937 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade43to44 1.0.0
2023-10-28 18:49:33,957 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade44to45 1.0.0
2023-10-28 18:49:33,977 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade45to46 1.0.0
2023-10-28 18:49:33,997 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade460to462 1.0.0
2023-10-28 18:49:34,019 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade462to47 1.0.0
2023-10-28 18:49:34,040 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade47to48 1.0.0
2023-10-28 18:49:34,060 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade48to49 1.0.0
2023-10-28 18:49:34,080 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade49to410 1.0.0
2023-10-28 18:49:34,102 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade52to53 1.0.0
2023-10-28 18:49:34,122 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade53to54 1.0.0
2023-10-28 18:49:34,140 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin VersionUpgrade54to55 1.0.0
2023-10-28 18:49:34,167 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin X3DReader 1.0.1
2023-10-28 18:49:34,201 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin XmlMaterialProfile 1.0.1
2023-10-28 18:49:34,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [538]: Loaded plugin XRayView 1.0.1
2023-10-28 18:49:34,222 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [454]: Loading all plugins took 3.5384981632232666 seconds
2023-10-28 18:49:34,238 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
2023-10-28 18:49:34,249 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.016564607620239258
2023-10-28 18:49:34,250 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [256]: The preferences file cannot be opened or it is corrupted, so we will use default values
2023-10-28 18:49:34,251 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [263]: The preferences file 'None' cannot be found, will use default values
2023-10-28 18:49:34,251 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [266]: Completed loading preferences.
2023-10-28 18:49:34,284 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [304]: Created system tray icon.
