12 hours ago, Dustin said:They are detached because your are significantly under extruding..
Your top surface is actually equally as bad and shows this as well.
Your either printing too cold or your flow rate is too low (or both)
And what do you suggest changing in the print profile?
- The filament size is correct.
- The nozzle size is correct.
- The wall ordering is "Inside to Outside".
- The temperature is correct (and using Simplify 3D with the same temperature I have no problems)
- With the THIN WALL TEST I have a correct result.
I attach the profile I am using
Dustin 84
GregValiant 1,141
Also, make sure your wall ordering is "Inside to Outside". Some under-extrusion coupled with the outer wall going down first can drag the too-skinny filament across the middle of the hole instead of it staying where it was put.
