You could try using something small (like a pin or a toothpick or I'm not good at thinking of examples) to try and get that bent pin back into position.
That just looks like a standard USB extension cord though, Type A male to Type A female. There's absolutely no shortage of those, just look on Amazon or whatever. It might not exactly fit into that bracket, but that's what you have a 3D printer for 🙂
FWIW: USB On The Go isn't a type of cable, it's a (fairly old) protocol designed so that things like smartphones which are usually peripherals (remember the days when you had to plug your phone into your computer to sync stuff?) act as a USB host and connect to peripherals on its own (like reading a USB drive or connecting to a keyboard). You do get cables called OTG cables because they're usually port combinations you wouldn't normally see (like type Micro USB Type B male to USB Type A Female to connect a device to a micro USB port on a phone before we were blessed by USB Type C).
Edited by Slashee_the_Cow
ahoeben 1,951
Your local Ultimaker reseller will know for sure, but they are probably much more expensive than finding a "panel-mounted USB OTG cable"
NB: I am actually not 100% sure it is a USB OTG cable (or what the exact difference is between a USB cable and a USB OTG cable) but all the micro-USB to USB-A cables that I have seen of this gender are USB OTG cables.
Edited by ahoebenLink to post
