Because the error is in the height, and that's the Z axis, there is no belt to tighten. I have checked the screws that attach the rod to the step motor. I did run a PID and made the suggest adjustments. There was a little improvement on the height error, but still off by 1.2mm on 40 mm height print.
Slashee_the_Cow 267
Is the H32 properly tuned? Make sure everything's straight, belts have appropriate tension, wheels are correct tightness, stuff like that. I had a problem on my Ender-3 v2 Neo once which was basically the same thing, turned out one of the wheels on the Z axis gantry was too tight so that the printer wouldn't go up as much as it wanted to each time.
