You can just fix the model for now - I mean it's pretty obvious to you, hopefully, what the problem is. Just remove any inner walls that are *inside* the model where there shouldn't be any "magic" walls.
So I still think this is the best way to pick cad software. I did not create this but I think it's fantastic:
- 1
gr5 2,173
Almost certainly an issue with the model. Are you by any chance using blender or sketchup? If so then most likely the problem is with "normals". Read about normals for blender or sketchup and how to fix them.
There are other possibilities.
Actually I think I see a more serious problem already. I can see your cylinders have walls inside the part. That's a no-no. You can't have walls *inside* a solid. Unless their purpose is to create an air pocket. That's almost certainly the issue. Most cad software will not let you create walls inside a solid like that. I'm guessing you are using blender or sketchup.
Mkono1 0
Hello, thank you for the help. If it's not too general of a question, what software would you recommend? I tried to use freeCAD but it didn't work very well.
