Hello, thanks for your fast response.
QuoteI'm going to assume you mean 0.4mm 🙂. 4mm would be one hell of a nozzle.
Yes, a small typo. Sorry. haha
QuoteDoes it start when leaving the Z seam or on the way back?
It appears after leaving the z seam.
QuoteYou're not at 100% flow, but that should affect things equally. I normally set my initial layer flow to 105% to aid adhesion, but if adhesion isn't a problem, don't worry about it.
The flow was calibrated, so the specimen can stay in tolerances I set before for my experiment.
QuoteAlthough I can't help but notice: you're printing PLA at 250°?!?!!?!!?!?!!!?!!?!!!?!??? I've never seen it done that hot. The PLA+ I get at do at 210, the regular PLA at 200 and silky at 205.
Yes, actually the Silk PLA by Colorfabb has a recommended printing temperature from 225-235°C. With temptowers I checked all the temperature settings possible and at this setting it still looked fine. Not even overextruding. And for my design of experiment I need to have two temperature settings (a "colder" and a "hotter" one).
The initial layer horizontal expansion was set to a negative value to remove the elephant foot i'm getting while printing seven of those specimen.
So far on the first layer with this setting all lines where connecting greatly.
I've tried now to print them with the value 0 and the bottom layer is connecting now not even at all.
Slashee_the_Cow 280
Also: infill isn't the problem here. At least not yet. The bottom layer is skin.
Now looking at the first layer...
Looks like it shouldn't be a surprise you're getting gaps.
Turning on a second bottom layer and looking at it:
It's a little bigger and the skin is being printed thicker... so does that mean?
Yes, it does. So if we disable the negative initial layer horizontal expansion (it's in the Walls section) what does the first layer look like?
Looks like the second skin layer - if you had one - would have been printed. I can still see tiny gaps, but they might get filled in as it oozes. And I am looking straight down, zoomed in, which doesn't do it any favours.
I tried a bunch of other settings and nothing seemed to have a significant impact.
Slashee's Conclusion:
