3 hours ago, gr5 said:People who know your patricular printer will be able to help you much more than I as I've never touched an ender 3 of any type.
Someone call for me? I have an E3V3SE. I've never seen underextrusion that bad though. Worst I've seen was some dodgy filament I had running through a Bowden tube from a filament dryer outside my printer's tent, except the filament was so inconsistent it pulled the tube (which was taped to the top bar of the printer) down to a couple of inches from the extruder, and actually managed to pull the filament dryer (on rubber feet) towards the tent... and even then it was still getting about 75% extrusion.
I will second @gr5's call for printing slower: most filament spools will have the normal printing speed and temperature listed on them, make sure you're not going above the recommended speed.
Other than the usual stuff like make sure your nozzle is clean (if you've never done that, heat up the nozzle and stick the nozzle cleaner that comes with the printer up there a bit to see if anything is caught) I can't think of anything. If you have a Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project) you can post that would help so we can see if there's anything obviously wrong the settings.
- 1
gr5 2,178
The print in the upper photo looks quite good. That's the typical quality I see on most 3d printers.
The print in the lower photo looks bad. It is severely underextruded. The gaps between the filament are more than the amount of filament so you have less than 50% extrusion. maybe 30% extrusion. So 70% less than nominal. This is severe.
If you print 3X slower it will help a bit. I don't know what is causing your underextrusion as there are literally hundreds of causes: feeder issues, filament jammed somewhere, semi clogged nozzle, printing too cold, printing too fast, layer height too thick, bad cooling fan above heat break. That's an extremely short list of common causes. People who know your patricular printer will be able to help you much more than I as I've never touched an ender 3 of any type.
