"What material?" PLA - in this specific case, Polaroid PLA for blue and Amazon Basics for black, but this has happened with Sunlu PLA as well
" It's kind of shiny - would it happen to be PETG?" Using Sunlu I set nozzle temp to 210 to avoid clogging, but for Polaroid and Amazon Basics, nozzle temp was 200
"What is the build plate temperature?" I set the bed to 70 (some prints might have been 60, and then subsequently increased to 70 to try to counteract the warping, using the brim, etc)
"What is the build plate made of?" It's the frosted PEI plate - this https://www.amazon.com/Creality-Printing-Magnetic-Flexible-Platform/dp/B09QCL4KFN/
"Do you have any way to check if the temperature is uniform across the surface?" I do have a digital infrared thermometer gun - I could give that a try
Edited by DustinPlease do not post affiliate links here.
GregValiant 1,258
What material? It's kind of shiny - would it happen to be PETG? What is the build plate temperature?
What is the build plate made of? Do you have any way to check if the temperature is uniform across the surface?
