Usually it should print fine - those overhangs look to be a little steeper than 45 degrees but I think it would print...
I don't think they'll fall over exactly as slashee says or maybe she's simplifying a bit but I'm more worried it won't stick well enough to the bed and, well, fall over. As slashee says.
You are going to waste a lot of filament regardless as you learn to print. I like to say it takes about 100 prints before you are pretty successful. And then when you switch to another filament, such as nylon, it will take another 100 prints to master that material.
So my point: I think the support looks fine. I'm just worried about how well it will stick as beginners aren't good at that detail (making it stick so well you can lift the printer with that print).
1
Slashee_the_Cow 621
I'll put my money on "probably won't print". I'd be surprised if those legs didn't fall over under their own weight.
Use the Support Blocker tool
to create a support blocker, then switch to the move tool, click the blocker to make sure only it's selected, then open the Per Model Settings and click the second icon (Print as support) :
Now use the move and scale tools (make sure to turn off Uniform Scaling if it's on), I'd put it about halfway along a leg (you want it to go from the bottom your mesh to the floor) and big enough to support as much of it as possible. Then just copy (Ctrl+C) and paste (Ctrl+V) one for each leg.
Edited by Slashee_the_CowLink to post
