GregValiant 1,258
There is a bug in the "initial_extruder_nr" replacement pattern. It always returns "0" rather than the actual tool number. You have it in two places in your startup gcode. Hopefully it will be addressed in Cura 5.7.0.
A workaround is to remove the temperature lines from your StartUp Gcode and allow Cura to determine temperatures. It might not be as efficient as a custom one but it should work.
This is from the BIBO definition file and has my suggestions.
;M104 T0 165 ; remove
;M104 T1 165 ; remove
M109 S{material_print_temperature_layer_0} ; alter
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z2.0 F400 ;move the platform down 2mm
;T0 ; remove
G92 E0
G28
G1 Y0 F1200 E0
G92 E0
;T{initial_extruder_nr} ; remove
M117 BIBO Printing...
KenO 0
Open ticket = 00835580
Problem parameters:
- Cura_SteamEngine 5.6.0
- BIBO2 dual printer
Complaint:
Extruder no longer heats up with new GCODE line =M109 T0 S(200, 0)
Workaround:
uninstall Ultimaker Cura version 5.6.0
reinstall version 5.5 to get working GCODE line =M109 T0 S200
Additional workarounds - you may edit your GCODE replacing all instances of "M109 T0 S(200, 0)" with "M109 T0 S200" or install the interim version 5.7.0-alpha.0
Edited by KenOadditional workarounds
