I can ssh in, but wasn't sure where the logs were stored. I didn't see anything in var.
Are both nozzles hitting the glass at the same time? I guess not? That wouldn't make sense I think?
No the right nozzle hangs lower like you say. It hits the glass first and then the head pushes down on it until the second nozzle hits the glass.
So first the right nozzle hits the glass and then does the bed quickly drop down?
No the bed drops shortly after the second nozzle (on the left) makes contact. Then the test fails. So Right nozzle touches glass, the head moves lower until the left nozzle hits the glass, then it drops.
gr5 2,176
Only after that it tests the left nozzle?
Ideally both tests should stop right when the nozzle hits the bed. If it keeps pushing for like 3 more seconds then there is a problem.
Having a sensor value of 2.3 is excellent. Anything below I think 8 is good.
When the right nozzle is down it should be 1.5mm lower than the left nozzle +/- 0.7mm.
You can see what that measured value is by looking in the logs. You can ssh to the printer if it's in "developer mode". Or you can just put a flash drive in there and in the menus you can dump the logs to a flash drive and examine them. Look at the date/time to find the most recent and search for these key words:
"peak" and "Preliminary"
