DivingDuck 104
I did some tests beginning the week and was often annoyed about "not watertight" models. They are since years as I print them quite often in the past (most of them was CAD models from Fusion360).
Then I thought us one of the most printed models: The 3DBenchy. Guess, what happen...
Shouldn't at least the 3DBenchy slice w/o errors? Regarding errors, pls. see the the error description shown in the picture, it's speechless as well 😉
I had also some crashes during slicing that was reported automatically, so they should be available.
Cura then is in a slicing loop that you can only break with closing Cura. The part itself is ok.
Two or three plugins wasn't working, but that was expected (I did report them to the plugin owner).
Looking forward for the next release. 🙂
I attached the log file. Please let me know if anything else is needed.
Torgeir 242
Hi Folks,
As I'm in my third day of testing this last Cura 5.7.0-beta.1.
There are issues with this version I did not see yesterday, so be aware of this.
If you slice any model (stl file and all of them do not "leak" or having other issues), then start a playback of the line track during build up. At the last point of the model, Nozzle freeze and time glass shows up -then Cura shut down.
Ufp model Created by this version was uploaded to Cura 5.3.1, the nozzle stopped in same position but this version did not crash.
Model looks ok., but Cura just quit before nozzle leave the printed object.
OFC., did not try to print anything..
Thanks
Torgeir
