Thanks ! I have been playing around with this setting in a range from 100 to 125 % remarkable difference !
not yet optimized, but at least it is a good start,
I am wondering how the line thickness setting is influencing the result?
does it have a lot of effect on the result product, or is it just to determine the number of lines in cura?
im relatively new to this matter(as you probably noticed..)
gr5 2,176
You will get much nicer results (typically but probably not in your case) if the letters are inset instead of sticking out. That may be good or not for cookies - not sure.
You can definitely get those filled in. It looks like you have quite a bit of underextrusion - the flat layer below has lots of gaps. There should be no gaps there either. It may be the same problem (underextrusion). Try printing at half the speed you were printing at and/or clean out the nozzle.
I think underextrusion is mostly your only issue however it may also be slicing this way on purpose. There are so many settings that can affect this. It's good to look at the print in PREVIEW mode in Cura to know if it will have gaps. Instead of me listing 30 to 50 settings for you to check, please post your project file so someone can look it over to see if anything needs to be changed in your cura settings.
To do this, in Cura, do "file" "save project file" and post the resulting file here please. We will be able to see your STL file (your model), where you placed it, if you scaled it, what printer (machine) profile you have, material profile, and all of the 500 or so settings you are using.
