If these are files that have printed fine before now then try cleaning the nozzle, check the front fan is working continuously at and above 40C or maybe you might need to dry the filament.
The first layer looks a little underextruded and you really want to squish hard to get things to stick. How hard the first layer squishes is the most important thing by far but not the only thing. some (not all) of the other things are removing surface oils (that come from your fingers probably), glue, brim, bed temp.
squish
1) This is a UM3 right (I don't think you answered slashee's question)?
2) Do you use active leveling (I don't on my UM3)?
Assuming you do manual leveling, turn the 3 bed screws CCW as seen from the bottom to move your bed up just a tiny bit. Turn them all the same amount, about 1/2 turn. This should increase squish without changing the "level" part of leveling.
material
Is this PLA? I don't think you mention anywhere. This is crucial information.
glue
3) Did you use hairspray recently? I don't like hairspray much because it can get all over the printer and cause havok with all the moving parts.
bed temp
4) Do you have one of those contactless IR thermometers ($7 at harbor freight)? I recommend you get one. Check the bed temp with that by pointing straight down (any kind of angle will reflect and you'll get the wrong temp). It should be 60C. Your temp sensor on the bed may report 60C when the bed is actually only 30C.
Please respond to all 4 questions!
- 2 weeks later...
Hello everyone, sorry for not replying, my notification emails were off and I managed to solve the issue.
1) Yes it's a UM3 and yes I use active levelling.
2) The material is PLA
3) I used to use hairspray but I recently stopped since cleaning the bed with soapy hot water gives me much better results even though I have to wash it quite frequently.
4) The bed sensor works fine I think since the bed gets really hot to the touch.
I also tried to clean the nozzle as suggested by mrender.
It turns out the filament just got stuck in the feeder. The knurled wheel was carving into the material so the filament could not move down properly. So yes it was just underextruding. It was such a simple thing!
Thank you everyone for your help though, next time I will know what to look out for.
There is always something to learn!
Rarely, the problem is at the feeder - for example it could be the feeder tension is set too loose and then yes it will grind the filament or the print will have 100 retractions on the same bit of filament. But much more often something is happening at the nozzle end (the hot end) and yes it grinds at the feeder but the cause was something far from the feeder.
1
just one shot out of the blue, but feeder problems could also include a worn out feeder arm, like in this post:
Regards
1
Slashee_the_Cow 347
Hard to tell because the forum crushes image quality after you upload it but it looks like it's underextruding, very significantly in some parts. Have you calibrated the E steps for your printer?
(Also helpful to know to try and diagnose: what printer is it, what material is it, what temperature settings do you usually use)
