Thanks for the tip; unfortunately I have had the pleasure of soldering a couple things on my U1, not my favorite thing in the world but I have everything I need.
The original issue was the heated bed reading hot when it was actually at room temperature. I was hoping it was a loose wire but I could not be sure due to the ensuing chaos.
I'm hoping all will be well after I fix the connections, but is there another possible issue regarding the temperature misreading that I may need to solve?
IRobertI 502
Ouch... It's certainly fixable but it might not look very nice. All you need to do really is to scrape off the soldermask from the lifted traces (the black "paint") so that you get to the copper underneath. Then just solder a wire between the newly exposed copper and the corresponding pin of the connector (that's not a relay, it's simply a connector). If you haven't done any soldering yourself it might be a good idea to try to find a friend/family member/neighbour who has. It's not a difficult process but trying to repair something is probably not the best project to start with. That and having to buy the tools for it if you don't have them already or plan to do more soldering in the future.
It probably wouldn't hurt to glue down the connector as well when you're done to avoid it happening again.
