I have both Ultimaker2 and an UP plus (not the UP plus 2) and I use and I am happy with both. I would not go for a Cube simply because of the high filament cost, I have no idea on its print quality.
I would not say either UM2 or the UP is the better - they are different.
If you are going to print ABS only and the UP build volume is enough then that's the choice. People have had mixed results with PLA on the UP but it is possible. The UP philosophy is to use a raft and the new UP plus 2 autoleveling expects it as it does the correction on the raft. It is possible to print raftless though and I do it all the time. The mechanics on the UP are not the best and I need to re-level the bed at lot. The UP software does not allow for temperature selection other than PLA/ABS. ABS temperature is 270 degrees C, so you have to use their filament or make yourself a temperature mod that will allow you to use any ABS. UP filament handling is very good and I do not get clogged nozzles or stalled filament. The extruder is mounted on the print head which a lot of people around here will tell you slows things down. It might in theory, but in practice the UP print speed blows the UM2 away.
On the other hand the build volume of the UM2 wins over the UP which is too small for a lot of jobs I do. Its also focused more on PLA printing than ABS. PLA warps a lot less than ABS so is better for larger builds. UM philosophy seems more to raftless printing which I prefer, but you can use a raft if you want to. Mechanically the UM2 is rock solid. Much better than the UP. The print bed leveling is very quick and easy to do, it can be tedious on the UP. The UM2 filament handling is not so good. I don't really like the use of 3mm filament and a bowden tube and would prefer the UP system of putting the extruder motor on the head near the nozzle.
So if you want to print small ABS models, go with the UP.
If you want larger PLA models then go with the UM2.
I'm happy with both and would not like to be without either.
IRobertI 514
There was a similar thread a couple of days ago. Have a look:
http://umforum.ultimaker.com/index.php?/topic/5057-unique-selling-points-of-the-ultimaker2/
Of course feel free to ask for more input or more specific questions.
