Imported obj files needs to be scaled and rotated. After doing so i like to save them. Cant check now but as I remeber loaded gcode files cant be scaled if I want to print in another scale without having to rotate again.
Whatever the reason is for me to want to save the model, if there is a save model I would suppose that it's meant to work.
I have saved other parts of the model with no problem but the part in question wont save.l
I dont think there is anything special with the part that dont save exept for it beeing larger than the one that I did manage to save.
gr5 2,333
Cura doesn't let you edit stl files (other than scale and rotate) so I'm not sure why you would then want to save the file you just loaded. I don't see the point.
Cura lets you save gcode files however. Those are what you need to then print your model on the printer.
Cura also lets you save the "profile" which are all those settings you can control.
