If the problem persists, post some photos here so we can see what it looks like.
I had the exact same problem with my new Ultimaker Original. There is even a faq entry on https://www.ultimaker.com/pages/support/faq/ultimaker-original-troubleshooting.
Look for "The hot end of my Ultimaker is leaking. There is plastic forming on top of the aluminum heater block."
IRobertI 520
You probably just need to tighten it a bit more. And don't worry, some leaking PLA wont cause any more damage than making the block look ugly![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
First though, make sure that you assembled it correctly:
http://wiki.ultimaker.com/Ultimaker_rev.4_assembly:_Extrusion_head#Lets_start.21
If you have then try to tighten it a bit more. You must do this at printing temperature (say 200-220C) or else the cold PLA will act as cement and you'll break something before you're able to tighten anything. So heat up the head and then tighten the nozzle tighter to the block. If that's not enough tighten the brass tube as well by holding the block still while twisting the PEEK (the brownish thing that the brass tube screws into). Be careful as the tube is quite thin and brass is a weak metal.
There might be a tiny bit of leakage even after tigthening but it will most likely plug itself after a while.
gr5 2,194
As long as it isn't dripping on your part I would ignore it. It will tend to cook over many days and turn into a gunk that will plug any leaks.
