It's a nice idea, but the nozzle size and fans will impede the shape and size of parts you want to make,
but, the software used to do this, could turn all 3D printers in a very nice 3D milling machine
and why not print that on it's side and add some support you cut away afterwards ?
IRobertI 513
It's an interesting idea but it seems a bit time intensive and finicky with the very dense support "mould" being printed first and then covered in tape. Seems like going down in layer thickness would produce similar results. He's using fat 0.25mm layers (although he calls them very thin..) which I'm guessing is sort of necessary to compensate for the randomness of the tape. Going down to 0.1 and 0.06 layers you're taking away a lot of that stepping. I printed a frog yesterday at 0.06mm and I have to get the light to hit it juuuust right to be able to even see the layers.
I think varying the layer height in conventional slicing could produce really really good results as well. Use nice and chunky layers for straight walls and go down to thinner layers where there's curves.
