Ah yes! Indeed! :oops:
Okay, so there it makes me even more scared. :oops:
A nice solution would be to 2h printing with a first file.
2 hours more with a second file.
And so on.
Except that. If I do that, how to make this task automatically. I do not Pronterface.
gr5 1,858
I have done prints > 24 hours. And I had a failure (nozzle clog) on one. I was able to continue the print - it was on the UM2 with heated bed so the most important advice is to keep the bed hot and don't panic. You can wait a few hours before continuing. If the bed had cooled the part would have popped off the bed.
To continue the print I had to use pronterface to move the Z axis up and down until I found the exact layer that had just finished. Then I had to edit the gcode - deleting all the begining part and adding a G92 code for the Z axis. Let me know if you need more details.
