You can use either or both. Personally I use the knob on the front first, if I can't get it to where I want it I fine tune with the back screw.
Hi, thanks for replying. My confuse part is this:
1st round
When leveling the build plate you must follow
the step 4/21 until 10/21 on the display where the
first step 4/21 control the height by
rotating this button. to get 1mm.
In the step 5/21 you rotate this left build
plate screw under the build plate to control the
height between the nozzle and the build plate.
In 6/21 you adjust a similar build plate screw on
the right hand side.
2nd round "Fine Tune"
With a piece of paper.
There is 3 screw below the build plate. 2 in front and 1 behind.
So my question is:
For this part, do I still turn the rear with the rotating button or the screw below the build plate?
IRobertI 513
