Dim3nsioneer 557
It's maybe worth mentioning that there are different types of stepper drivers. AFAIK the Ultimaker stepper driver have their own board design. It is pin compatible with the Pololu driver boards (and also run with a Pololu A4988) but may have a different way to set up the current and a different reference voltage maybe.
On the Wiki page of which you posted the link, you have the different types on the bottom. Make sure you're not driving the driver significantly into overcurrent otherwise you really have to replace them.
Although they are not too expensive, you would have to wait for the new drivers to arrive and couldn't use your machine... :sad:
gr5 2,210
google "pololu current". These parts are pin compatible with pololu drivers. One of the 2 pins on the adjustable pot is at the voltage you need to measure. There is a formula that converts voltage to current. I think you simply multiply by some constant but forget what the constant is.
If you break one of these they are very inexpensive and you can replace with several choices of replacement. The key information is to know that they are called "pololu" and google will take care of you.
