After you hit save or whatever there is a non-obvious step where you have to select PLA again.
Not only that, but it is kind of buggy in the original firmware so you might want the latest firmware which comes with the latest Cura. With older firmware, after saving PLA settings you have to change the LED settings and then maybe power cycle? It took my about 10 tries. With the newer firmware you just have to know about the last step where you select PLA.
1
gothampixel 10
On the printer before you start the print go into MATERIAL > SETTINGS > CUSTOMIZE. Keep all of the settings for the material you are using but change the build plate temp and then store as preset.
