You might also have underextrusion - it's difficult to change from ABS back to PLA - ideally you want to print at least a few meters of PLA at high speed and temp (240-250C) to get it all out. You can also use the "atomic" method but your photo doesn't show underextrusion - I guess I would have to see a lower level or a side view.
gr5 1,971
We usually call this "pillowing" and I'm not surprised it is worse with PLA. This is fixed (or greatly improved) with 100% fan. By default the fan doesn't reach 100% until 5mm up I believe (cura setting) so I would change it so that it is at 100% by the time it hits the top layer fill - 1mm is a good value for this typically as it allows the fan to come on slowly over 5 to 10 layers (depending on layer height).
Also doing more layers will help.
1) What is the thickness total of your part?
2) What is your top/bottom thickness?
Pillowing example:
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/?p=17300
