how come it doesnt print on every model?
thats what i thought, but on one of the ones ive done it definately would have been as it was a 90 degree overhang, the only 2 models its done it on is this one, and a duplo brick type of thing. the brick was the first and i assumed it was the program the guy had used to make the file that did it, it didnt have the supports in cura either. That one was a 90 degree overhang too.
Got me baffled
It depends on where the overhang is and which type of support you're using "Touching buildplate" or "Everywhere". With the first it will only generate support if the support can be built from the buildplate all the way up to the overhang. With the second option it will generate support that can be built either from the buildplate and up or from the actual object itself and up.
Load up a model in cura, switch to layer view and play around with those two settings and you'll see the difference.
Ive got it on touching buildplate since i started it. That makes sense but 2 of the models were almost identical in the way the overhang is, one did and one didnt. Ill have a look at that setting though and see if i can find out why its not doing it all the time.
Thanks
As Robert said, check it in layer view, you'll see if cura is generating supports or not.
It is for this, but still not for another
Post a picture of layer view for this "other" part that has no support. Usually it's obvious why no support.
I printed this skull and those supports are well needed. Sometimes you would think that Cura would place supports on some parts but it doesn't and usually this works well. If it doesn't support it's probably because Cura is smart enough to know it will print fine.
This skull will print okay without support but the cheek bones will be messy as there are some big overhangs and the right side has a part that is printed in the air so you would have a hole there.
Ill get a picture on as soon as i get out of bed lol, yeh i agree the supports are great. I just wish i could turn them on constantly
I think you can change the angles where support is needed in the expert settings if this is what you want? I believe the default is add support for 60° angles
IRobertI 520
You must've enabled support in cura since it isn't in the model itself.
