which paper thickness to calibrate bed?
caro
Posted · which paper thickness to calibrate bed?
My Ultimaker 2 arrived yesterday and I had to callibrate the bed (like everybody).
Now, I just wonder which paper thickness we should use to callibrate the bed?
I used 80g/m^2 paper double folded
What is your experience?
    I use 80gm2 also, and as fingerpuk allready said, don't fold it. Once you did it 2 or 3 times you will get the feeling. You can also while the printer is laying down the first few lines (skirt if configured) still adjust it carefully (like 1/4 or 1/2 a turn) no problem. HAPPY PRINTING!
    I did it again with a paper of 80g/m^2, not folded! Th result is much much better!
    Thank for your help!
    Paper varies quite a bit, and you need to use the same paper all the time, if possible.
    If you use flat metal feeler gauges, I find that a bit of drag on .002" (or .05mm) is about right.
        • 21 replies
