Are you in Russia? Please post what country you live in as part of your profile location. I recommend you contact support also and they will likely give you a free bed replacement.
All PT100 parts are interchangeable electrically but not necessarily mechanically as they come in all kinds of shapes and sizes. PT means Platinum. 100 means 100 ohms at 25C. At 20C one would expect about 108 ohms.
Here is a table that translates temperature to expected resistance:
http://www.intech.co.nz/products/temperature/typert.html
You may have also damaged the solder joint where the connector is soldered to the heated bed. You might want to reheat those connections with a solder iron.
eldrick 64
You need to contact Ultimaker Support directly, not just post in the Forum.
http://support.ultimaker.com/index.php?/Tickets/Submit
