Printing tip of a pyramid
alexanderswo
Posted · Printing tip of a pyramid
Hi togehter,
I have a problem with printing the tip of small pyramids. The last few layers always melt togehter and build a big blob. -What settings would you suggest to get this right? -I*m on a delta tower printer and use 3mm colourFabb PLA XT.
(how do I resize an attached picture?)
Thanks,
Alex
    Hi Alex
    First, welcome to the Ultimaker forum. Have some fun here and check out if an Ultimaker printer would be a fine addition to your delta tower. ;)
    The usual way is to lower temperature for the last layers where the print speed is small and make sure the fan(s) is/are at full throttle to cool the deposited material.
    With XT it's somewhat more tricky as it will change transparency when lowering the temperature. I would maybe try it with 220°C for layers with print speed below 25mm/s.
    If you use Cura, you might try the 'cool head lift' feature.
    and increase layer time... there is an option in Cura...
    and decrease print speed.
    There is a plugin (teakatz) installed by default in your Cura where you can specify different settings when your print reaches a hight.
    For example, for 10.2 mm and more: print speed 30%, new temp,....
    Or print another object that is a bit higher next to it and print them at the same time so that the pyramid has time to cool down between layers. Just add a small cylinder or tower next to it.
        • 9 replies
