To see settings you can usually do "file" "load profile from gcode..." and Cura looks at the last line in the gcode and if created by Cura it should have one huge binary string there and can read the settings out of that sets all the settings to that. It's backwards compatible and safe so newer settings that were created in newer versions of Cura won't be affected.
gr5 2,331
For fast print do 240C, 70mm/sec, .2 layer
For more beautiful robot do 220C, 30mm/sec, .2 layer
