I did the procedure you describe and it cured the blobbing, but the white bowden holder now sticks up above the head by maybe 3mm.
Next time it needs adjustment, should I cut off a few mm of the bowden tube to avoid this?
No, let it stick up, that's what makes it grip the tube properly. The problem is that the "roof" of the head is too thin. The purpose of the horse shoe is to push the collet up and lock it into place, ideally the horse shoe should just barely fit under there. But since the "roof" is so thin the collet has a lot of room to move even with the horse shoe in place.
Look at the feeder on the back of your printer. Notice how there's a raised ring around where the collet sits to take up the slack?
Some day you will damage your bowden with the 4 blades in the "bowden holder" and it won't stay up any more. Only when that happens should you cut off a few mm of the bowden. But the bowden holder will still "stick up".
I notice that the bowden holder now sticks up at an angle to the head, and I'm thinking that a stretched-taller horseshoe clip could straighten out the filament entry into the head.
I took the Ultimaker 2 Bowden Clip from Youmagine and scaled it taller in Z in Cura. I made several horseshoe clips ranging from 2.0 to 3.0 times taller and tried them out under the Bowden holder until I found one that just fit.
It had the intended effect - the bowden tube now stands straight up at the head, so the filament has a lower-friction path at entry.
With that and another one under the bowden clip on the extruder, blobbing is a thing of the past - it's back to new performance, aside from major underextrusion.
I use another clip, also from youmagine. They are available in different sizes. I used 2.5 mm and it works perfectly fine. Definitely an improvement regarding oozing.
https://www.youmagine.com/designs/bowden-locking-clamp-clip
gr5 1,843
yes. You can increase the 4.5 to 6.5 or you can lock in the bowden.
You don't need any clips. First a definition:
"bowden holder" - That thing on the print head that you push down in order to pull up and remove the bowden. It has 4 metal blades inside that dig into the bowden. The little colored clip goes under it. It's off-white colored.
Simply loosen the 4 long thumb screws such that the print head relaxes about 1mm. Then push down hard on the bowden (the bowden holder allows one way movement). I guess I would remove the clip first but it shouldn't matter. Then screw the 4 long thumb screws tight again - make sure no wires get stuck in the gaps when you are done (inspect all 4 sides of the black print head - black seams). Now the clip should be useless and the bowden should be tight. If not repeat but go 2mm relaxed instead of 1mm.
I did this and was able to lower my retraction distance back to 4.5mm.
