I think splitting off the "nose" to get two flat bases for the print would be the best really. If not I would print it with the nose down and add concentric circles for support that I would break away afterwards. Both approaches would need some sanding afterwards if surface quality is of high priority. But I think a single seam would be easier to get rid of rather than lots of contact points around the nose. You'd also get some pretty bad overhangs from the looks of it.
Dim3nsioneer 557
I recently printed something slightly similar and succeeded by putting the part on its tail. I added some one line thick perpendicular support sheets to the lower few centimeters and used a brim. The support was easy to break off. My object was about 15cm in height.
