acceleration configuration ???
david-ganon
Posted · acceleration configuration ???
As both of the above posters noted - the thing it fixes the most is ringing - look at the pictures in this topic to understand:
http://umforum.ultimaker.com/index.php?/topic/2532-prevent-ringing-wobbly-surface-after-sharp-corners/?p=18006
It also makes the printer quieter if you lower acceleration and less shaking the table and also makes it print slower - especially if there are lots of sharp turns that the head has to make such as text. But on a real printer decreasing acceleration doesn't slow prints down too much. Cutting acceleration in half in theory could slow down print time by 30% (square root of .5 is .707) but in practice it might only be 5% if you have many long straight lines such as infill.
Cura assumes I believe 3000mm/sec/sec acceleration (or maybe 5k?) so if you go slower Cura will not correctly guess your print times.
