Dim3nsioneer 559
Have you installed the Arduino drivers which came with the newer Cura versions? I think to remember that new drivers were included recently and that Cura needs these new drivers to work properly. But I'm not 100% sure...
Thank you for quick answer. Actually, I did try with two printers - Reprap Mendel and Rostock. Mendel has a Marlin Reprap (Meltzi board) version firmware and Rostock has latest Marlin version for delta printers. Strange thing is the fact that previously up to Cura 14.03 had no issue. The OS is windows xp. Thank you for help.
Could, please, someone help with some advice? It is so frustrating not been able to print from Cura.
It's sometimes a bit difficult to give further advice if one does not get an answer on questions already asked... :(
I am sorry. Yes. They have been automatically installed at the end of installation when I installed Cura. Were there other drivers than those included in the installation package?
I have windows 7 32 bit version and the same problem,
14.01 was working super
14.03 did not like the new printing module
14.06 installed the new arduino drivers and cannot connect to the printer since that time. cannot even role back the driver installation. I'm afraid i have to reinstall.
Unless somebody have an idea maybe??????
Connection issues debugging steps to isolate your problem - but before reading this - is it possible you download UM2 firmware into a UM Original? Or UM Original firmware for the UM2? If so don't panic, you can fix it.
usb debugging (post #7):
http://umforum.ultimaker.com/index.php?/topic/5100-how-to-update-um2-firmware/?p=46156
also win 8.1 drivers:
http://forum.arduino.cc/index.php?topic=205837.0
Tried it all (I think)
Used a diverend laptop to isolate a driver problem
tried all kinds of software from replicator 34 windows to printrun to Cura 14.06 install default firmware.
The result stays "Not connected"
Is there a way to reset the arduino 2560 or must I buy a new one?
Thanxx for reading,
Han
No way to make the connection works. Strange thing is that 14.01 is working, all previous versions, but all other upgrades up to date do not work. I had in the past this issue with one version of MatterControl but in the next version they fixed the issue. There was a similar story version "N" did/does not want to connect but all versions, including, up to "N-1" and all versions starting "N+1" did/does work.
Update,
removed the Arduino 2560 completely from the Ultimaker and ran the firsttime wizard from Cura 14.06,
including the firmware upload.
Now its working :-P
Han
Yeah. If I select the automatic baud rate after two or three trials it connects. Unfortunately each trial takes up to 3 min but it works. If I select manually the baud rate it does not connect, just closes the port.
illuminarti 18
What Operating System is this? And what type of printer are you connecting to?
