Brute force, bad for slicers, better for extruders
Posted · Brute force, bad for slicers, better for extruders
I just wanted to say, 150mm/s and 0.32mm layer thickness at 200 degrees through a 0.4mm nozzle.
And I'll leave these here.....
IMAG0341
IMAG0340
IMAG0339
IMAG0338
IMAG0337
Also, 200mm/s retraction...
Ok that was kind of a lie at the top.
It will absolutely do that, but I have to turn the stepper current up too high, as it stalls out at that speed and lower current. With a normal current setting, I can run 100mm/s at .32mm layer thickness and 200 degrees.The filament never slips, the stepper just stalls, which is awesome as the filament neer grinds out so I havnt lost a single print since installing it. =D Happy days.
    At 100mm/sec .32 layer .4 nozzle, that's 8mm^3/sec. I've seen people do 15mm^3/sec (about twice as fast) even on the UM2 (but at 230C! 200C is impressive) (although my limit on my UM2 is closer to 8mm^3 at 230C).
    However what really impresses me is 200mm/sec retraction. The menu system on the UM2 only lets you go up to 35mm/sec which seems ridiculously slow. And on the UM Original I think around 30mm/sec is the max speed.
    Maybe you should do a more exacting test like this one...
    http://umforum.ultimaker.com/index.php?/topic/4222-pulling-force-of-um-extruder/?p=34887
    Nice!!
    I have been thinking of designing something very similar to that for my UM2, but I did not find the time yet.
    Is there a spring somewhere pushing one of the feeding rollers towards the other one?
    How does the filament look after passing through the feeder?
        • 4 replies
