The most important things when working with Sketchup & Cura, are imho:
1. disable all "Fix horrible" settings, as Dim3nsioneer mentioned.
2. Fix all horrible stuff yourself
Meaning, make sure there is nothing "red" in the "X-Ray" view, such as internal planes, or holes in your mesh (like missing faces).
Dim3nsioneer 557
Check the expert settings: Is any 'fix horrible' option set? If yes, disable it...
