I agree, can you explain what you want to do differently? Maybe sketch it out in an image and post here?
I've had no problem printing down to .3mm and lower but you would need to change the first layer height.
Also you can always drop down to gcode to do things Cura won't let you.
nallath 1,079
Might be that I understand you wrong; but I've been able to print objects that were 0.3 mm high.
