That's useful, thanks! I don't think I will need to do that, firstly I should try out all the basic settings. Thanks for explaining the thing with Cura. Is there any other slicer that allows some other modifications of the print settings? I see that in Cura it's possible to change the outer layer printing speed but is it possible to change it's thickness? From, let's say, 0.06 to 0.02?
What is more, giving that there's only one surface I'm taking care of - the upper surface (the element is a button, everything else will be hidden), is it possible to print everything lower that this surface as quick as possible (not taking care of quality) and make only this one surface look good, printing it slow? There's an option for "Initial layer thickness" but Cura says it's not a good option for making it thicker than 0.3 mm.
gr5 1,873
It's really a slicer question and you can use many slicers with the UM. But most people use Cura and Cura allows a different speed for:
outer shell
inner shell
infill
For example if the shell is two passes you can have the outer (visible) shell print slower than the inner shell and you can have the infill also print faster.
But be aware that with a .4mm diameter nozzle (that sort of sets your XY resolution) it's hard to get a ton of plastic through that small a nozzle. It can print about 10 cubic mm per second at normal printing temperatures. For .1mm layers that is (10/.1/.4) about 250mm/sec. For .2mm layers it's 125mm/sec. And most people print at least 3X slower (3 cubic mm/sec).
You can drill out the nozzle to for example .8mm and loose some XY resolution but gain massively in print speed.
