Thanks for the tip about adding additional supports. Will keep my fingers crossed for the print that is in the process right now, but have added aditional supports already to the model, so if the first one goes to hell, I will go fresh with the modified model.
IRobertI 513
Bed levelling is irrelevant as you get past the 2nd to 3rd layer so that's not the problem here. What you're seeing is curling of the edges. The edges curl up and end up being higher than intended and the head then crashes into them. Both gr5 and AaronAlai have topics discussing this that are worth reading through. I'd link you but I don't have time at the moment.
On that image showing supports I would strongly suggest that you add additional support struts to the taller supports. Just click somewhere on the support and drag out another line to the "floor". That will help anchor them in place.
