It looks like you have some pretty bad backlash, I'd start by fixing that. There's some helpful tips on fixing it at the following page. The pictures show an UM2 but the same applies for your UM Original as well:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#circles
nallath 1,120
I see under extrusion on the top of your print. Also, the results tend to be best if you use 2x your nozzle as shell thickness (in this case 0.8). I've had exceptionally awesome results with shells of 1.2, especially combined with little infill.
The higher parts of the print seem to suffer from layer shift, this is usually caused by your pulleys slipping while printing. This could also cause the elliptical circles, but these can also be caused by a high 'head resistance'. If the steppers are not powered, it should be easy to move the print head by hand.
