I would unscrew the fans and the metallic bracket that holds them in place. Then you can bend the metallic bracket back to its original shape.
I have an Ultimaker 3 which earns its keep well. I run quite a few different filaments, some of which need relatively high temperatures. I've now had two print heads fail because of the transparent plastic lever degrading, so that it crazes and splits at the screw head.
I understand this isn't currently a replaceable part - a shame - but I wonder if others have had similar experiences?
If so, does anyone have ideas as to how the thermal stress on this point could be reduced?
Chris Woolf
41 minutes ago, chriswoolf said:I understand this isn't currently a replaceable part - a shame - but I wonder if others have had similar experiences?
There is no official spare part, but search on Thingiverse or Youmagine, there is a lever you can print. Works fine, because someone else has tried it some weeks ago.
Found it : https://www.thingiverse.com/thing:2742644
or here is another one: https://www.thingiverse.com/thing:3745208
Brilliant! Thank you.
I'm clearly not alone;}
I did draw the part out and a partly successful replacement but it didn't last long. I suspect I didn't come up with as good printer settings.
chriswoolf
IRobertI 516
I have a hard time imagining a printing scenario where the printer could do that to itself to be honest.
