When in doubt, always use liquid nitrogen!
Using those cooler packs you use for camping might better. Those remain cool for a long time.
I am, slowly, trying to change the setup to a push construction, instaed of the pull concept, because there is so much friction in the short curve at the bottom. The grinding will be related to that I guess..
Or you could replace the pla at that point by thin steel cable or so.
The 100 ml syringe (http://www.polyservice.nl/Injectiespuit-p-16476.html) feels easier to push, but has more material to displace, have to test that.
If it works to push the material, maybe it could work in combination with the Doodle3D box….
Seems someone had the same idea. A more generic setup for various liquids.
Also my syringe takes a lot of fraction to operate. That could also be a cause of the grinding. I am more thinking using air pressure to operate it so it will not effect the filament at all. Air pressure I have for my airbrush. There are quite some examples to be found. In order to do this I need to find the right parts....
This is what finally worked; a combination of different ideas and some of my own.
http://www.thingiverse.com/thing:14421
- parts from Joris, some files are old and don't fit any more. The printhead layout changed a lot.
http://www.thingiverse.com/thing:21302/
- from mechadense. But with this setup the winding part broke (lots of force here). But this idea works because the use of spectra line through a bicycle/motorcycle brake tubes instead of thick filament.
I also had to replace the cap of the syringe part by a wooden layered part; the printed one in XT broke...
and of course made some spacers for the limit switches X ,Y and Z to prevent collision. Especially for the Z height to compensate for cookies or so.
when placing an object in Cura, mind that the object will not be printed in the center but more to the right and back. This could probably be edited in the gcode as well.
Here is the gcode, for a chocolate star with cold extrusion:
;Sliced ?filename? at: Sun 24-08-2014 13:38:22
;Basic settings: Layer height: 0.3 Walls: 14 Fill: 0
;Print time: #P_TIME#
;Filament used: #F_AMNT#m #F_WGHT#g
;Filament cost: #F_COST#
M302
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G92 X0 Y0 Z0 E0 ;reset software position to front/left/z=0.0
G1 Z15.0 F?max_z_speed? ;move the platform down 15mm
G1 F200 E3 ;extrude 3mm of feed stock
;go to the middle of the platform (disabled, as there is no need to go to the center)
;G1 X?machine_center_x? Y?machine_center_y? F9000
G1 F9000
;Layer count: 1
;LAYER:0
M107
G0 F9000 X98.55 Y60.53 Z0.30
;TYPE:WALL-INNER
G1 F600 X100.79 Y60.54 E0.01190
G1 X101.91 Y58.60 E0.02380
G1 X103.02 Y60.54 E0.03569
G1 X105.26 Y60.53 E0.04758
G1 X104.14 Y62.47 E0.05947
G1 X105.26 Y64.41 E0.07137
G1 X103.02 Y64.41 E0.08327
G1 X101.90 Y66.35 E0.09516
G1 X100.79 Y64.41 E0.10705
G1 X98.55 Y64.41 E0.11895
G1 X99.67 Y62.47 E0.13084
G1 X98.55 Y60.53 E0.14273
G0 F9000 X99.63 Y58.54
G1 F600 X101.91 Y54.58 E0.16696
G1 X104.18 Y58.54 E0.19118
G1 X108.74 Y58.52 E0.21540
G1 X106.45 Y62.47 E0.23962
G1 X108.74 Y66.42 E0.26385
G1 X104.18 Y66.41 E0.28807
G1 X101.91 Y70.37 E0.31230
G1 X99.63 Y66.41 E0.33652
G1 X95.07 Y66.42 E0.36074
G1 X97.36 Y62.47 E0.38496
G1 X95.07 Y58.52 E0.40919
G1 X99.63 Y58.54 E0.43342
G0 F9000 X98.48 Y56.53
G1 F600 X101.91 Y50.56 E0.46997
G1 X105.33 Y56.53 E0.50652
G1 X112.22 Y56.52 E0.54307
G1 X108.76 Y62.47 E0.57962
G1 X112.22 Y68.43 E0.61618
G1 X105.33 Y68.41 E0.65273
G1 X101.91 Y74.39 E0.68928
G1 X98.48 Y68.41 E0.72583
G1 X91.59 Y68.43 E0.76239
G1 X95.05 Y62.47 E0.79894
G1 X91.59 Y56.52 E0.83549
G1 X98.48 Y56.53 E0.87204
G0 F9000 X97.32 Y54.53
G1 F600 X101.91 Y46.54 E0.92092
G1 X106.49 Y54.53 E0.96981
G1 X115.70 Y54.51 E1.01869
G1 X111.08 Y62.47 E1.06757
G1 X115.70 Y70.44 E1.11645
G1 X106.49 Y70.42 E1.16533
G1 X101.91 Y78.41 E1.21421
G1 X97.32 Y70.42 E1.26309
G1 X88.11 Y70.44 E1.31197
G1 X92.73 Y62.47 E1.36085
G1 X88.11 Y54.51 E1.40973
G1 X97.32 Y54.53 E1.45861
G0 F9000 X96.16 Y52.53
G1 F600 X101.91 Y42.52 E1.51982
G1 X107.65 Y52.53 E1.58102
G1 X119.18 Y52.50 E1.64224
G1 X113.39 Y62.47 E1.70344
G1 X119.18 Y72.45 E1.76465
G1 X107.65 Y72.42 E1.82586
G1 X101.91 Y82.42 E1.88706
G1 X96.16 Y72.42 E1.94827
G1 X84.63 Y72.45 E2.00948
G1 X90.42 Y62.47 E2.07069
G1 X84.63 Y52.50 E2.13189
G1 X96.16 Y52.53 E2.19310
G0 F9000 X95.01 Y50.52
G1 F600 X101.91 Y38.50 E2.26664
G1 X108.80 Y50.52 E2.34018
G1 X122.67 Y50.49 E2.41372
G1 X115.70 Y62.47 E2.48726
G1 X122.67 Y74.46 E2.56080
G1 X108.80 Y74.42 E2.63434
G1 X101.91 Y86.44 E2.70788
G1 X95.01 Y74.42 E2.78142
G1 X81.14 Y74.46 E2.85497
G1 X88.11 Y62.47 E2.92850
G1 X81.14 Y50.49 E3.00204
G1 X95.01 Y50.52 E3.07558
G0 F9000 X93.85 Y49.62
G0 X93.85 Y48.52
;TYPE:WALL-OUTER
G1 F600 X101.91 Y34.48 E3.16146
G1 X109.96 Y48.52 E3.24733
G1 X126.14 Y48.48 E3.33319
G1 X118.02 Y62.47 E3.41906
G1 X126.14 Y76.47 E3.50492
G1 X109.96 Y76.42 E3.59079
G1 X101.91 Y90.46 E3.67666
G1 X93.85 Y76.42 E3.76253
G1 X77.67 Y76.47 E3.84839
G1 X85.80 Y62.47 E3.93426
G1 X77.67 Y48.48 E4.02012
G1 X93.85 Y48.52 E4.10599
G0 X93.84 Y53.52
G0 X93.84 Y53.52 Z5.30
;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
Nice that you posted your wonderfull solution. For the parts that did not fit anymore I just cutout the corner with a saw. But your parts will be more sturdy. Also note that you are using a 100ml syringe.
ahoeben 1,634
At the ulti-evening I tried freezing my buildplate to make the nutella less droopy once printed. Should have used liquid nitrogen:
http://3dprint.com/9148/3d-printed-ice-cream/
