Not with this batch. The filament has been rather consistent in the past. I will give that a try and get back to the board with a reply.
I see you have a mendel. What is your overlap %? If it's higher than 30% then you should lower this to 15% and instead tighten your belts as you probably have some backlash (aka play) and fixing this with infill overlap is not the best solution.
But to answer your question, Daid has a newer version of Cura - not released yet - that will allow you to create regions of your print and adjust any parameter for any region. So you will be able to do exactly this in the next major release.
IRobertI 497
Have you measured your filament properly so that it isn't thicker than cura is expecting?
