Posted · Cura (14.07) doesn't start on Win7pro 64bit PC
Cura is running without any problems on my 3 years old business-PC.
On my high-performance home-PC Cura doesn't start.
- no error message during installation
- uninstall/reinstall doesn't help
- running as administrator doesn't work
- antivirus off - doesn't help
- start from windows start menu: nothing happens
- when starting direct from C: Create \ Program Files (x86) \ Cura_14.07 \ CuraEngine.exe I see a black popup for 1/2 second:
"C: \ Program Files (x86) \ Cura_14.07 \ CuraEngine.exe
This program is distributet in the hope it will be useful did, but WITHOUT ANY WARRANTY: without even .... ...
You Should Have ... received a copy of the GNU Affero General Public Licenses along with this program. ... ...
Default config "default.cfg" not used
M107
G1 F2700 E-4.50000
G1 Z2009428.63
G0 X0.00 F9000 Y0.00 Z5.00
M104 S0; extruder heater off
M1 40 S0; heated bed heater off (if you have it)
nothing more happens.
Any idea? :???:
    I don't think CuraEngine is the UI. Pretty sure it is the slicer. Try running Cura.bat from a command line to see if it gives you any information. The Cura UI is written in python and that is what the .bat starts.
    kayoo - why post a topic and not even follow it? Click on "follow this topic" in the top right. If you ever read this topic.
    I have win7 64 bit and cura works fine - it's not the operating system.
    We have a wide range of windows versions on machines in the office, so if Cura didn't work on one of them on general, I would know about it. But there are tons of different possible setups. (MacOS has the same issue, and a few more)
    Sorry, I havn't seen it. Thank you for your advice!
    Thank you! :-P
    This is the information:
    C:\Program Files (x86)\Cura_14.07>cura.bat
    Traceback (most recent call last):
    File "C:\Program Files (x86)\Cura_14.07\python\lib\runpy.py", line 162, in _ru
    n_module_as_main
    "__main__", fname, loader, pkg_name)
    File "C:\Program Files (x86)\Cura_14.07\python\lib\runpy.py", line 72, in _run
    _code
    exec code in run_globals
    File "C:\Program Files (x86)\Cura_14.07\Cura\cura.py", line 13, in <module>
    from Cura.util import profile
    File "Cura\util\profile.py", line 22, in <module>
    import numpy
    File "C:\Program Files (x86)\FreeCAD 0.14\bin\numpy\__init__.py", line 168, in
    <module>
    from . import add_newdocs
    File "C:\Program Files (x86)\FreeCAD 0.14\bin\numpy\add_newdocs.py", line 13,
    in <module>
    from numpy.lib import add_newdoc
    File "C:\Program Files (x86)\FreeCAD 0.14\bin\numpy\lib\__init__.py", line 8,
    in <module>
    from .type_check import *
    File "C:\Program Files (x86)\FreeCAD 0.14\bin\numpy\lib\type_check.py", line 1
    1, in <module>
    import numpy.core.numeric as _nx
    File "C:\Program Files (x86)\FreeCAD 0.14\bin\numpy\core\__init__.py", line 6,
    in <module>
    from . import multiarray
    ImportError: DLL load failed: Das angegebene Modul wurde nicht gefunden.
    I am not an expert, so I don't know what that means. :???:
    Also look in output.txt in C:\Program Files (x86)\Cura_14.07
    sorry, there is no output.txt in C:\Program Files (x86)\Cura_14.07 :???:
    Can you temporarily uninstall FreeCAD? looks like it is picking up stuff from the FC installation.
    That's it! I uninstalled FreeCad and Cura. After reinstalling first Cura and then FreeCad both run perfect.
    Thank you anon4321, Daid and gr5 for your fast help!
    Oh, yes, FreeCAD is causing crap with Cura. They install some global stuff that they shouldn't. Not sure if they fixed it in their latest release.
    I've had no issue with the latest release of FreeCAD.
    Though as in Kayoo's case, I've always installed Cura first and then FreeCAD. So it's possible that the installation order is significant.
    I do have the same problem also. I had try the version 14.07 and the latest. The following are the output.txt file:
    File "C:\Program Files (x86)\Cura_14.09.1_RC1\python\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line 14660, in <lambda>
    lambda event: event.callable(*event.args, **event.kw) )
    File "Cura\gui\splashScreen.py", line 15, in DoCallback
    self.callback()
    File "Cura\gui\app.py", line 99, in afterSplashCallback
    from Cura.gui import mainWindow
    File "Cura\gui\mainWindow.py", line 17, in <module>
    from Cura.gui import sceneView
    File "Cura\gui\sceneView.py", line 28, in <module>
    from Cura.gui.util import previewTools
    File "Cura\gui\util\previewTools.py", line 12, in <module>
    from Cura.gui.util import openglHelpers
    File "Cura\gui\util\openglHelpers.py", line 17, in <module>
    glutInit() #Hack; required before glut can be called. Not required for all OS.
    File "C:\Program Files (x86)\Cura_14.09.1_RC1\python\lib\OpenGL\GLUT\special.py", line 323, in glutInit
    _base_glutInit( ctypes.byref(count), holder )
    TypeError: 'NoneType' object is not callable
    may i know how can i solve this problem?
    thank
    self.callback()
    thank
    That's the total lack of 3D card drivers.
    I had try to do a clean installation of my nvdia graphic card driver and with latest directX. The problem remain the same. Could you advice other alternative solution?
    You can also check if some application installed a global "glut32.dll" in windows/system32, as that should not be there and might be causing a conflict which causes this error in return.
    thank i found a software use install that dll. After uninstall it then everything is ok
    I had the same problem with this glut32.dll. On my laptop it was the installation of Haskell.
    de-installated HASKELL and everything worked fine.
    best regards
    Stefan
    i deleted my old 4.1 folder in %appdata%
